indexing array without a loop
I would like to make and insert elements to each index on an 1D array. but, I don't want to use loop. How can I input my data into 1D array increasing and indexing array? whenever We want to make a new array, Do We have to use a loop control?
(3,099 Views)
To create an array, all you have to use is the Initialize Array function or just drop an array constant onto the diagram. You can then use either Replace Array Subset or Insert Into Array.
(3,099 Views)
