indexing array with a push button
           I'm trying to do a circular array where the array size is 5. I'm looking for inputs if we can do the same with out using a while loop and timer, but with a push of a button. Attached you will find the code i'm working with.
thanks.
(3,348 Views)
Accepted by gsajja
I used an event structure.  Also I replaced your case structure with the Quotient and remainder VI.
Tim Elsey
Certified LabVIEW Architect
(3,332 Views)
thank you Sir.. thats what I was looking for.
(3,310 Views)
Then mark Tim's reply as the solution to your question rather than your own Thank You reply. If you go to the options menu to the upper right of your message, you will be able to unmark it as a solution. Then mark Tim's message as the solution.
(3,303 Views)
