index array
i tried it, but it didnt work. i dont think my string is in array.
Message Edited by krispiekream on 04-22-2008 03:30 PM
Krispiekream
Message 11 of 16
(1,053 Views)
Krispiekream
Message 12 of 16
(1,052 Views)
is it possible for me to make TempStart as an array within my program?
what can i do to make ArgValue to be 37, 42, 35
Parse.vi
Message Edited by krispiekream on 04-22-2008 05:17 PM
Krispiekream
Message 13 of 16
(1,022 Views)
thank you altenbach and everyone for helping me on this.
i got it to work after carefully reading altenbach msg,
"You need to make "tempstart" an array instead of a scalar.
You string array element already has the values as a comma seperated list, so all you need to do is get the array element, use "spreadsheet string to array" with "," as delimiter, "%f" as format and a 1D DBL array as type. Try it! "
thank you so much..
Krispiekream
Message 14 of 16
(1,003 Views)
You did not follow my instructions. Let me highlight the important part:
If you don't wire the array type (lower left connector of "spreadsheet string to array"), it assume a 2D array. Did you really read the entire error message? It says it right there!
Solution: Create a constant on the type connector and resize the index to 1D.
Message 15 of 16
(997 Views)
yeah, i figured that out after i re-read your instructions
Krispiekream
Message 16 of 16
(987 Views)
