in-coming string to numeric indicator
I am getting read values as string in following format
\s\s\s\s\s\s\s\s\s0
\s\s\s\s\s\s1000
\s\s\s\s\s75000
-\s\s\s\s\s1000
how can i format them to numeric and show them in numeric indicator(I32) like
0
1000
75000
-1000
etc
Read characters are always 10 in number and i want them to display as signed numeric
Thanks and regards
(3,645 Views)
HI
Check the attached VI.
I hope this helps.
(3,620 Views)
Accepted by rajxabc
Hi rajxabc
please check whether this meets your requirement.
______________________________________________
Kudos are welcome
(3,614 Views)
@LV_user1 wrote:
HI
I hope this helps.
woahhhh way too confusing 😉 Try this. If they are in one string, you will have to use my method. If those are each separate strings in your example Gogineni's solution works. But, you can change the numeric type to an I32, keep the %f, and then there is no need for the coerce to I32
(3,612 Views)
Thank You Gogineni, it works perfect.
(3,598 Views)
Hi rajxabc,
All the best
Kudos are welcome
(3,593 Views)
