impulsive analog output control
Hi, my requirement is as below:
1. continuously analog output sine wave;
2. impulsive analog output (or very short-duration constant output) when the condition of the analog inputs is satisfied;
My problem is:
I can continuously output a sine wave and suddenly switch to a triangle wave for a short period, and then goes back to sine wave. But the minimum period of the triangle wave is always 1 second.
For example, if I set the switching-on time of the triangle wave is between 4 to 4.1 second, the result is always from 4 to 5 second. How can I give a implusive output or give a constant output in 0.1 second?
Many thanks for your help.
Lau
(3,107 Views)
Hello Lau
I am the applications engineer who will be looking into your query and helping you to get your program running as you want. As I understand you are acquiring data and then using a trigger to start the output? Please correct me if I have misunderstood.
I have a few ideas but would like to see your code if that is possible, this way I can make suggestions relating to your code and offer you more personal advice.
Thank you
Stephanie L
Applications Engineer
National Instruments UK and Ireland
(3,082 Views)
Many thanks, Steve.
Forget the data acquisition of my code. I want use time to trigger the square wave output signal, but I want the period of the square wave signal is very short, e.g. 0.1 second. Please see my attached pictures.
Using the attached code, it always gives me a sqaure wave signal last for one second period. I do not know why. Maybe I am not using a real-time labview system? or are there better way to carry out this task?
Thanks again.
Lau
(3,069 Views)
Look at the sampling info input to the waveform generator.  You have nothing wired in, so it uses its default values of 1000 Hz, 1000 samples.  Thus 1 second of data.
(3,060 Views)
Hello Lau
Thank you for your reply, I am looking into your query and am looking at examples which implement what you are looking for.
Would it be possible to have the code in vi form? Just so I can see what configurations you have and to make suggestions based on your code.
Thank you
Stephanie L
(3,044 Views)
Attached. Thanks very much for your help.
(3,040 Views)
Thanks a lot for your help. It works Smiley Happy
(3,037 Views)
