impact test force
I am newbie in labviewprogramming. Then I have enquiries about my project which is using labview. I amusing impact test with NI DAQ 6251, impact hammer B&K 8200 andaccelerometer B&K 4371 then attach it in a structure. I have done somenecessary setting and it works. I can get some graphical result for magnitude (dbchecked) phase, coherence and others are works too. But, it is very important to meto get the value of the force when I hit the structure with the hammer. I shouldget this force value, to make the amplitude respond from accelerometer relativelycompared by the force. Can any one helpme what should I do with – especially – the labview program, so that it canresult in the force data. Then, how to get the value of the amplitude per force(m/N, in Y axis) versus the frequency (in x-axis) in a graph/chart. I really needyour help for my research.
(3,044 Views)
Hi rayen,
Can you explain more what you mean when you say you are reading magnitude, phase and coherence? What type of sensors are you reading from?  Are you reading a analog voltage signal?  If you know the mass of the hammer and can read the acceleration, the product of the two would be the force (F=ma).
Can you post what you have so far in your VI?
(3,008 Views)
recommend that you refer to related discussion:
http://forums.ni.com/ni/board/message?board.id=231&message.id=1258&requireLogin=False
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(2,937 Views)
