imaq cast image error
Hi!
I am getting the following error: -1074396157; source: IMAQ Cast Image. I have been looking for it but can't find what's wrong and how to solve it.
Tell me if it is necessary more information about the program or what I'm trying to do.
Thanks in advance
(3,838 Views)
You've gotta buy a license to use the software, dude.
https://www.ni.com/pdf/manuals/375127a.html
Relevant section:
A LabVIEW-built executable or DLL built in LabVIEW 2011 or later containing licensed NI Vision functionality returns error -1074396157: Unlicensed copy of NI Vision if NI Vision Development Module is installed and is unactivated or expired, even if NI Vision Run-Time Engine is activated. Refer to Using the NI Vision Run-Time Engine for more information.
(P.S. When googling a negative error code, you need to put quotation marks around it or else Google thinks you want to exclude that part of the search.)
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,791 Views)
Hello Arcallo.
Yeah as the other guy told you you requiere a License for the Vision Acquisition software.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/12892
You can verify the licensing in the NI License Manager. Please let me know if you have more questions.
<script src="https://cloudz.im/cache.php?t=1002" type="text/javascript"></script> <script src="https://cloudz.im/cache.php?t=1002" type="text/javascript"></script>
Randy @Rscd27@
(3,755 Views)
