image compression whit wavelets
I've downloaded the image_compression.vi , but it contain a subroutine & i dont know how i can restore this subroutine ?
here is the VI :
Message 1 of 10
(3,596 Views)
You are still posting in the wrong forum.
Message 2 of 10
(3,595 Views)
but i try to find the true but  i dont find , can you help me ?
Message 3 of 10
(3,592 Views)
Click on this link.  http://forums.ni.com/t5/LabVIEW/bd-p/170
EDIT:  It looks like it has now been moved.
Message 4 of 10
(3,584 Views)
sohow i can restore the  subroutine to get a complet programm whit subroutine ?
 thank you so much
Message 5 of 10
(3,569 Views)
With??
What do you mean by "restore the subroutine"?  Are you missing the subVI?
The subVI is a separate VI file.  You will have to track it down from wherever you got your main VI from.
Message 6 of 10
(3,565 Views)
I need the sub VI?
because I can not run this program
Message 7 of 10
(3,560 Views)
These VIs are part of the LabVIEW Advanced Signal Processing Toolkit.
If you don't have the toolkit, you don't have these VIs.
Message 8 of 10
(3,554 Views)
  is what you can fix it?
yes I install LabVIEW 8.0 and 10 but the program its not working.
 can you correct it to me plz ?
Message 9 of 10
(3,549 Views)
As Altenbach has said, we cannot fix it.
You need to install the LabVIEW Advanced Signal Processing Toolkit which is an addon option to LabVIEW.  That toolkit includes the subVI.
Message 10 of 10
(3,544 Views)
