illegal board id error
i am trying to run some servo VIs. i am using 2 servo motors, a four axis controller, an isel made umi7765 control unit and a 7344 motion control card. altough i can tune the servos at measurement and automation explorer , i can't run a VI in Labview 6.1.
The error is " Error 12 NIMC_badBoardIDError illegal board ID assigned to your board in the configuration utility."
if someone know the reason of this it will be heplful.
thanks
(3,416 Views)
Hi!
NI-Motion installed two versions of software, FlexMotion and ValueMotion. You are trying to run the ValueMotion examples, but the PCI-73xx is not compatible with that older software. Use the FlexMotion examples instead, which are generally installed in the folder C:\Program Files\National Instruments\LabVIEW\examples\Motion\FlexMotion.
BR, Christian
(3,403 Views)
