How can detect the serial port is active
I made a program. It can read datas via serial port. But the datas wont came all the time, so the other part of the program not need to run. I want to put before the "reading serial port" a detection about the serial port is get a data. So the reading is wont start before datas are not coming. Can anybody help me how can i solve this problem?
Message 1 of 9
(4,177 Views)
Hi Zoyo, if you use the VISA- VIs, the functionyou need is "VISA Bytes at serial port". It shows, how many Bytes are available in the input buffer. You can find it here:
greets, Dave
Message Edited by daveTW on 11-22-2006 02:01 PM
Greets, Dave
Message 2 of 9
(4,165 Views)
You can also use events along with the bytes at port so you don't have to poll the bytes at port so often.  see the attached image
-James
Message Edited by James R on 11-22-2006 09:06 AM
- James
Using LV 2012 on Windows 7 64 bit
Message 3 of 9
(4,154 Views)
What function is that coming after the cluster in the Rx Data Loop?
Message 4 of 9
(4,131 Views)
This example uses queues to store the data until it is processed in the parallel loop.  the function after the cluster is enqueue element found in programming>synchronization>queue operations
-James
- James
Message 5 of 9
(4,123 Views)
Thx for all. I try to do it now.
Message 6 of 9
(4,104 Views)
James:
Can U attach the vi file about serial_interrupt ?
Message 7 of 9
(4,079 Views)
daveTM: So it's mean if the VISA Bytes at serial port value is 0, than the datas are not coming? Because if it's true I can put my whole program int Case Structure and i can say if the value is 0 do not doing anything, and if the value is bigger than 0, than wich program must to work.
Message 8 of 9
(4,071 Views)
Sorry for the late answer.
Yes, you're right, if this function gives a value back greater than zero, there was something received by your serial port. The NI- serial driver handles the serial protocol for you automatically and stores the received bytes in a buffer. When you use "VISA Read" this function only gives back the data of this buffer. So you don't have to read every single byte by byte but can wait until a certain amount of bytes are received and read them in one.
Greets, Dave
Greets, Dave
Message 9 of 9
(4,035 Views)
