ignore timestamp in Mixed signal graph bug??
Looks like bug in the mixed signal graph:
The property ignore timestamp is ignored 😕  , for arrays of wfrms it's always ignored 😞
While trying a workaround (adding  XY data) the second wfrm timestamp is now always not ignored ??
undefined
Greetings from Germany
Henrik
LV since v3.1
(3,146 Views)
that is strange. this VI works with me. Did you use LabVIEW 2014?
undefinedundefined
(3,101 Views)
undefined
undefined
A close look at subtle clues indicate a version previous to 2014 was used to create the post.  Some version that shows the con-pane all the time but not one with the new icon from 2014
I didn't bother to hit Ctrl+I and look at the source version info
"Should be" isn't "Is" -Jay
(3,089 Views)
Good capture! You are rigth about the version, I still use LV 12.0F3 (32bit)
Henrik
LV since v3.1
(3,085 Views)
