if statement
Hi everyone!
I'd like to do following statements in Labview.
if a=0.001
then b=0
        c=1
        d=2
        e=3
        f=4
else if a=0.002
then b=5
        c=6
        d=7
        e=8
        f=9
end if
Thanks!
Message 1 of 8
(3,996 Views)
What should happen if "a" is something else (not 0.001 or 0.002)?
Typically, you would use a case structure. Try it!
Of course you need to be very careful comparing floating point values. Whree does the "a" data come from?
Message 2 of 8
(3,993 Views)
Hope this is what you are looking for.
Run the VI and change the value of a.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 8
(3,985 Views)
(You might want to add a small wait to that loop.)
Here's an alternative version using arrays.
Message 4 of 8
(3,973 Views)
Sir
--Ranjeet
Message 5 of 8
(3,961 Views)
@Ranjeet_Singh wrote:
                           How you changed the controls and indicator. Never saw like this before.
If your create a front panet using 'Silver Controls' (and of course indicators) and downgrade it to any LabVIEW version lower than 2011. You'll see the same.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 6 of 8
(3,946 Views)
friend,
                            Looks like some kind of magic for me.
--Ranjeet
Message 7 of 8
(3,942 Views)
Yes, I started out with your code (which was silver style), but downconverted, because the OP did not say what LabVIEW version he has.
Message 8 of 8
(3,916 Views)
