if input is one constant from a range, is there a tool that can make output select for that number
I'm not really sure if this has a name, but I want to input a constant between 0 and 7. I would like there to be 8 outputs, and depending on the value of the input, the corresponding output is selected. The output could be 1,0 or T/F. I think I could achieve the same goal with a lot of programming, but I wondered if this was already a tool.  Thanks.
Message 1 of 8
(3,609 Views)
Put the eight values in an array and use the "input" to index the array for the output.
Unless I completely misunderstood your intention...
Message 2 of 8
(3,608 Views)
case statement? the cases can be setup to be your inputs, they don't have to be specifically 0-7, case can contain anything to output. Of course, if you want 0,1 in some cases and T,F in other it gets a bit more complicated, but that could be handled in a number of way.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 8
(3,604 Views)
I have made a quick sketch of what I need. Im not sure if this is what you were describing.  Thanks
https://docs.google.com/drawings/d/1ytM01yggd1WrcJT1ygPw_iouDmsntCCKYltCnb2YSSY/edit?usp=sharing
Message 4 of 8
(3,600 Views)
Can you just attach your drawing to a message.  I can't get into Google Docs.
Message 5 of 8
(3,582 Views)
Accepted by Adamramm23
Index Array will do what you want.  Just have all of your possible outputs in an array and index out whichever element you want.
Message 7 of 8
(3,574 Views)
Or are you looking for something like this?
Message 8 of 8
(3,570 Views)
