icon text format
I am using the line text 1, 2, 3, etc within the icon editor.  I can't change the format of the text.  Where can I change it?
Kudos and Accepted as Solution are welcome!
(4,283 Views)
What kind of "formatting" do you have in mind?
You can change the color for each line, centering, capitalizing, font style and font size. Look at all the option right there.
(4,276 Views)
The color of the text is all messed up.  I can't fix it.  I can change the color but there is always a shadow.  See attached.
(4,257 Views)
You might have multiple layers.  Try merge layers.
George Zou
(4,253 Views)
Accepted by jyang72211
This is because you have cleartype enabled and use a cleartype font. You should only use the "small font".
See also the following discussion: Words in icon editor get blurry
(4,243 Views)
What Altenbach said... use "Small Fonts".
(4,222 Views)
Thanks!!!!
(4,193 Views)
