06-01-2010 08:04 AM
Hi, I am doing an editor for TestStand. I have a tree control which represents the test sequence and I'd like to use the same symbols than TestStand. I can do it if symbols are .jpg or .png but not if they are .ico.
How can I do?
Thanks a lot.
06-01-2010 11:12 AM
I believe you've already asked this in the TestStand forum.
If this is a different question, it should be in the TestStand forum, as I don't see how this has anything to do with LabVIEW.
06-03-2010 02:21 AM
You don't see how this has anything to do with LabVIEW because probably the issue is not very clear. TS is just the object of the application. What I'm doing is a LabVIEW application. In this application I use a tree control, I'd like to use .ico as symbol.
I don't see how this has anything to do with TestStand.
06-03-2010 02:38 AM
06-03-2010
02:46 AM
- last edited on
10-01-2025
09:26 AM
by
Content Cleaner
Hi Logatto,
I want to suggest you these links:
http://zone.ni.com/devzone/cda/epd/p/id/3608
http://zone.ni.com/devzone/cda/tut/p/id/6607
Hope this helps,
06-03-2010 03:53 AM
Sorry for misunderstand, but was speaking about an editor then I took for granted that I was working with labVIEW.
However, using an external graphic program is not the best solution, I should convert the icon everytime I add a new one.
Thanks Matteo, but as I told you before, the issue is not with TS.
Thanks all.
