icon symbol tree
Hi, I am doing an editor for TestStand. I have a tree control which represents the test sequence and I'd like to use the same symbols than TestStandI can do it if symbols are .jpg or .png but not if they are .ico.
How can I do?
Thanks a lot.
(3,627 Views)
I believe you've already asked this in the TestStand forum.
If this is a different question, it should be in the TestStand forum, as I don't see how this has anything to do with LabVIEW.
(3,598 Views)
You don't see how this has anything to do with LabVIEW because probably the issue is not very clear. TS is just the object of the application. What I'm doing is a LabVIEW application. In this application I use a tree control, I'd like to use .ico as symbol.
I don't see how this has anything to do with TestStand.
(3,570 Views)
Hi logatto,
in your OP you always talked about TestStand... No mention of LabVIEW...
What about taking the ico-files you have and feeding them into a graphics file converter of your choice to produce PNGs from them?
(3,564 Views)
Hi Logatto,
I want to suggest you these links:
http://zone.ni.com/devzone/cda/epd/p/id/3608
https://www.ni.com/en/support/documentation/supplemental/08/teststand-user-interface-development-bes...
http://zone.ni.com/devzone/cda/tut/p/id/6607
Hope this helps,
Matteo Brunella
Application Engineer
NI Italy
(3,562 Views)
Sorry for misunderstand, but was speaking about an editor then I took for granted that I was working with labVIEW.
However, using an external graphic program is not the best solution, I should convert the icon everytime I add a new one.
Thanks Matteo, but as I told you before, the issue is not with TS.
Thanks all.
(3,538 Views)
