iam getting error no -10401 when i use pci-6250+scxi1120+scxi1303
(2,672 Views)
PCI 6250 is a M series card and SCXI modules can be multiplexed to it.
( I think so!
If it cannot be used for this purpose, somebody plz do correct me!
I remember reading that this card is not ideal for using to access SCXI modules in PXI-SCXI combo chassis, but I am not sure if it cannot be used in stand alone SCXI chassis too, as in this case Smiley Surprised)
If the compatibility is fine, check this: Have configured this PCI 6250 DAQ card as the card that controls this SCXI chassis that houses your 1120 on 'Measurement and automation explorer' ( MAX) ??
this error usually is shown if your hardware is not configured on MAX
Message Edited by devchander on 07-24-2006 02:21 AM
(2,644 Views)
Hello Inst,
Error -10401 is usually a Traditional DAQ error – what is the exact message you are getting? Other things that would be helpful for us is what version of the drivers you are using, what OS you are on, and what environment are you programming in (ie LabVIEW, CVI)? Also, Measurement and Automation Explorer (MAX) is a great troubleshooting utility, have you tested your system in it?
Also, what is your application? One thing I would try, would be to run a shipping example that is as close to your application as possible, and see if you get the same error.
Hope this helps, let us know what you find out.
Andrew
(2,630 Views)
