Database connectivity error
I get the following error when I use the vi : "DB  tools execute query":
Error 1 : "Conn getDataToModify.vi"<ERR>Object 0x2222222 is not valid.
I am trying to write arrays of data to an Access 2003 database using the following query:
INSERT INTO <table name> VALUES('<Data>')
Please advise,
Regards-
(3,097 Views)
That is an error that states your connection to the DB is not valid.  Try just opening and closing the connection to see if you get any errors.
(3,085 Views)
