iIwant find and replace value and combine two row which having G
Dear sir ,
Here i have Given a example my file which conatin G and R  i want to find all R and replace with G. and cobine in in one column.. example is given belowe
11 03 30 00 00  0.0000000  0 18G02G04G05G09G10G12G15G17G25G26G27R01
                                R02R12R13R22R23R24
 11 03 30 00 00 30.0000000  0 18G02G04G05G09G10G12G15G17G25G26G27R01
                                R02R12R13R22R23R24
here i have attached file and my programme
 11 03 30 00 01  0.0000000  0 17G02G05G09G10G12G15G17G25G26G27R01R02
                                R12R13R22R23R24
Message 1 of 11
(2,910 Views)
Accepted by Julian_prince
Perhaps it would help us understand better if you'd put the expected result in a screen-shot of your front panel.  I can't tell what you need.
Jim
Message 2 of 11
(2,901 Views)
Dear sir,
here i am unable to insert the image so i have attched the image file,
Message 3 of 11
(2,894 Views)
Savvy?
You'll probably need to fix something, but at least my picture matches yours (except for the empty element at [0,0]).
Spoiler
Rube-Goldberg candidate?
Jim
Message 4 of 11
(2,890 Views)
Dear sir ,,
Thanks for solution that is same what i want,, but  i want complete value which are inside of the file, only that RG row should combine,,and other parameter should remain as it is..
Message 5 of 11
(2,874 Views)
here is programme what imade from your image..
Message 6 of 11
(2,873 Views)
This?
Jim
Message 7 of 11
(2,868 Views)
That "image" is a VI Snippet.  You can drag it to your block diagram and it'll magically become LabVIEW code.  🙂
Jim
Message 8 of 11
(2,867 Views)
Dear sir,
Thanks for your reply,, but this programme work for single slot , i want to run it for entire file ,
here i have attached file and programme..
Message 9 of 11
(2,862 Views)
I think you're missing what I've done.  I've addressed every group of data from your file in the While loop, with the shift register passing the "offset past match" to the "offset" terminal in the next iteration.
Jim
Message 10 of 11
(2,860 Views)
