i want to get and set windows system time through lab view
Hi
I want to get and set windows system time with the help of lab view 8.5.
please help me out.
ekanth
(3,564 Views)
You can use the call library function node. Once you drop it on your block diagram double click it and you will be able to select the dllyou want to use. Choose kernel32.dll and you will see methods listed called getsystemtime and setsystemtime. Use those
(3,550 Views)
Did you try a search?
Change system time on Windows CE 5.0 with LabVIEW. It says Windows CE, but it should work on regular Windows as well. You will likely need to set the DLL for the CLFN to "kernel32.dll".
http://forums.ni.com/t5/LabVIEW/Is-it-possible-to-set-the-windows-o-s-system-clock-with-a/m-p/863056...
(3,541 Views)
