i want to do communication via ethernet using TCP/IP
i want to do communication via ethernet using TCP/IP i did it but code is runing but im not getting any output
(3,062 Views)
That is not enough to solve your problem.
Please post in bit more detail.
What happened exactly? are you getting any error messages.
Please post your code for simplifying further clarifications.
Mathan
(3,061 Views)
Look on this easy example: http://www.labviewtutorial.eu/viewtopic.php?f=14&t=328
You will find there two identical VIs (only port numbers are different). One is for PC1 and other for PC2. If you will get prodlems starting VIs, so look on your firewall settings, you have to unlock ports used in these VIs.
(3,056 Views)
