i want to display strings which are in case structure ,into one text box
Accepted by topic author sandy1
sandy1 wrote:
hi balaji,
thank you for ur reply. but problem is not solved.
i have added one moer event to my vi, where i want to displat all the "instructions " and "results" into two outputs.if i select "add" it should display "instruction and result" and if i select "sub"it should display "instruction and result " into the same place , where i have displayed the "instruction and results of "add".
What you're asking for is not very clear.  And the VI you posted some seem to show your new requirement.
If you have another event case you want to add, then move the indicators to outside the event structure.
One more thing you could do, (and I'm a bit afraid to tell you as it could lead to abuse and a case of "localitis") is to use a local variable of the indicators in the other locations you want to use it.
Message 11 of 11
(517 Views)
