i need the false case to keep on executing untill "OK" button is pressed.. please heelp me out..
have used one button dilouge box for a case structure .if the "Ok" button is pressed it is exicuting the true case .untill and unless i press the "OK" button it wont execute any thing...
sub vi-example.vi
main vi-ni.vi
(3,049 Views)
Why not just use a button on your front panel instead of the dialog?
(3,018 Views)
What you need as was shared on one of the 3 (!) Threads where you asked the exact same question, is an event structure. But you also need a nonblocking dialog box, like I have demonstrated how to build.
But Sir Crossrulz's question is also a good one: why not just use a button on the front panel?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,965 Views)
