i don't see my attributes in the tdms file (xls)
i don't see my attributes (per log entry) in the tdms file (xls).
have to investigate if it is not overwritten afterwards with entries without attributes, but nevertheless...
(3,646 Views)
Please include a Snippet of your code, or attach your VIs, so that we can better assist you. We are here to help, but we need more information than this to have a starting place.
Do you mean Properties? The TDMS Write VI function doesn't include attributes from the waveform, just the data.
Cheers
(3,644 Views)
If you are converting your TDMS file to an XLS file using the free addon, then your TDMS properties will be on the first worksheet.  The format isn't very clean but the data is all there.
(3,611 Views)
Hey,
also the attributes? This is an extra field in the waveform block next to the value Y when writing into tdms. I will include a snippet of the code tomorrow.
The properties are all ok. but not these attribute(s).
regards,
koen.
(3,603 Views)
Accepted by kdCMC
The Waveform attributes are not written to the TDMS file unless you write them as properties yourself.
Cheers
(3,600 Views)
