06-22-2009 10:49 AM
Hello all,
We are trying to add aditional security to a web based system thats being run by labview. We run on gweb as a server and use labview to create server side cookies. We would like to impliment microsoft httponly cookie format. Does anyone know if this is possible? the only examples we have found to do this have been for other scripting languages, it appears it may be as simple as adding info to the header of the cookie, but we can not tell for sure if that is the case, and if so if it is possible to add that info using the LV cookie vi's?
Any help or if someone has implimented it and could send a sample vi it would be greatly appreciated. (btw we are using LV 8.6)
Chris
CLAD
06-23-2009
03:53 PM
- last edited on
04-07-2025
10:39 AM
by
Content Cleaner
Hi Chris,
It looks like you may want to take a look at the Internet Toolkit to see if it will do what you want.
Flash
06-23-2009 03:57 PM
06-24-2009 11:34 AM
Hi Chris,
There is no input to change the type of cookie, however you will be able to change the header information by digging into theCreat Cookie.vi. Double click the sub-VI and you can modify it.
Flash
06-24-2009 01:35 PM
thank you for the information, would you be able to send a screen shot or the Vi with the header creation marked for us...we dug into some of the cookie VI's already and were not completely sure of what was happening inside them all..
again thanks!
Chris
06-25-2009 11:45 AM
Hi Chris,
So after taking a closer look at the VI, it looks like you will have to build the Cookie yourself.
Flash
