http header expect:100-continue
I am trying to make a HTTP PUT request to a webservice, which I can't get to work because it keeps returning the following error in its header: HTTP/1.1 417 Expectation Failed
In the body it explains that I have a header "expect:100-continue" in my PUT request header (see image).
I have tried everything to remove that particular header from my request (using LabviewHTTPclient.lvlib:removeheader.vi), but Labview still sends it.
2 questions:
- Is there a tool that lets me see what header/request labview actually sends to the webservice?
- how come I can't remove that header?
Thanks for your input!
BTW. I got it working in Curl, which I believe is used by Labview itself as well
(2,864 Views)
Hello Aartjan,
About the tool:
You could use wireshark (just an example).
About the header part:
Can you share your code or a simplification of it (Project and files [vi's..]) that allows me to test/reproduce/see what's going on?
To know what causes the issue we need to see your code.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,851 Views)
