html to mht
i want create a mht unique file instead a html file for my reports.
I doon't know how make an application to do it.
(3,440 Views)
Me too. I've been playing around with Labview for weeks trying to figure how I can generate a *.mht file instead of the HEML format. I use several graph in HTML record and they are exported as *.png files that are linked to the HTML report. This creates overhead and makes it difficult to transport electronically. Anyone got a solution for this?
(3,369 Views)
Thats a great question. At the moment, there is no built in functionality for creating an .mht file in LabVIEW. It sounds like a great product suggestion! Go to www.ni.com choose Contact NI >> Product Feedback.
Best Regards,
Chris J
(3,350 Views)
Do you know of a way that there may be possible to create a stand alone report with graph’s that are saved solely to one file that does not need a LV application to view?
Thanks for your feedback!
E-
(3,317 Views)
Hello E,
There are a couple of things you can try. The easiest is, if you have the Report Generation Toolkit, to simply create a Word document report and append the front panel image. Another thing to try is to create an html report and then programmatically create a folder that contains the report and the corresponding image file.
Best Regards,
Chris J
(3,294 Views)
