07-25-2005 07:55 PM
07-26-2005
04:41 PM
- last edited on
11-11-2025
06:16 PM
by
Content Cleaner
Check out this knowledgebase article that talks about the different GPIB errors and how to resolve them. The second error on the list is the one you mentioned, ECIC 1.
If you follow these steps and still get the same results then repost. Thanks!
JenK
07-26-2005 08:01 PM
07-26-2005 08:49 PM
It sound like you are working at a much lower level than you need to be.
What version of LV are you using?
Is there a reason you can't use the VISA drivers for the gpib communications?
Finally, what is the make/model of the electric load you are working with?
Mike...
07-27-2005 07:57 PM
07-27-2005 09:21 PM
