hs2 file
Hello everyone, I just have a simple question!
Can Labview open .hs2 files? I am trying to communicate with a different program that analyzes Laue diffraction patterns and saves the histograms/data as .hs2 files and I'm not sure if I am able to use LabView or if I should just work with python.
Thank you!
(1,679 Views)
Accepted by topic author Mk.2020
LabVIEW can open any type of file.  I don't know what an HS2 file is.  I'm going to assume it is sometime of binary file.  LabVIEW can open binary files.  It comes down to the programming you need to interpret that file and parse out your data of interest.
If you are lucky, you might be able to find someone who has already written subVI's to do that parsing for you.
(1,664 Views)
