hp E3631A
is this the right way, just to read and write to my hp E3631A. look at attach files please
thank u in advance
(2,887 Views)
If this is all in one VI, since your read and write are not connected, you don't know which will happen first and will try to execute in parallel. You should do the initialize first (once only), then the setup, then the read, and lastly the close. Connect all of the VIs by using the error cluster inputs and ouputs and the VISA reference. You may have to put a small delay between the setup and read. Good luck.
(2,886 Views)
