how we can merge vlc media player in the labview to play video in vlc ?
Does it have anything to do with merging VLC media player and LabVIEW?  If not then a 7 year old thread is not the best place to ask.  I suggest making your own thread wher eyou ask the question with words, and clear description of what you have tried and what you are looking to accomplish.
Message 21 of 32
(3,743 Views)
Dej,
You should be able to get the ActiveX of VLC from their web site.
However, the version of ActiveX is < 1.0
I would use Windows media player instead.
More reliabe, more users, and easier to get help.
George Zou
Message 22 of 32
(3,740 Views)
Zou ,
some how i managed to stream live video from my ipcam but is there any activex to record.
Message 23 of 32
(3,739 Views)
I am trying to record the video stream from my ipcam is there any  vlc activex or anyother way so that i could stream my cam and record .
Message 24 of 32
(3,738 Views)
I don't know if there is one.  Last time I used VLC to record audio was 5 years ago.  I had to use VLC as an external exe.  I used VLC with VLM config.
I used Windows media player for playback, in order to sync with video and TDMS data.
You should visit VLC forum for help.
George Zou
Message 25 of 32
(3,733 Views)
zou do  you example  have any example program for that if so please send me it will be more helpful
Message 26 of 32
(3,717 Views)
All,
Attached is a new version that uses the VLC ActiveX v2 interface that is currently available.  It seemed like the ActiveX library changed and the previous examples no longer work.  I tested this with vlc-2.2.4-win32.exe.
Gary
Message 27 of 32
(3,662 Views)
I have installed the VLC media player. But in the object list of the active X, I can not find the  "VideoLAN VLC ActiveX Plugin v1". Any idea will be appreciated!
Best regard
Message 28 of 32
(3,627 Views)
It is labeled "VLC ActiveX Plugin and IE Web Plugin v2"
Message 29 of 32
(3,618 Views)
in my Axtive X, I just can not find the "VLC ActiveX Plugin and IE Web Plugin v2". I have already installed the VLC media player.
Best regard.
Message 30 of 32
(3,613 Views)
