how to write a specific column data in database
Hello All,
I am using the database connectivity tool kit to read data from .accdb file, I can able to write all the data in to database but not able to write only specific data column in to database. Please suggest.
Message 1 of 10
(4,511 Views)
Hi Swasa,
There are two ways to read the column information from the database.
way1: Execute the query "
select * from <Column Name>
using the  'DB Tools Execute Query.vi> inside the 'Database\Advaced' palette.
Way2: Use the 'DB Tools List Columns.vi' from the  'Database\Utility' palette and use the LV functions to filter out the not required data
Srikrishna
Srikrishna
Message 2 of 10
(4,474 Views)
If I understand correctly, you'll want to look at UPDATE statements to be able to change the values stored in a single column (it may be that you can only do this one row at a time, in which case use a For loop as needed).
You can't usually enter data into a database table with only one column, unless the other columns all have either defaults or allow null.
The SQL syntax to do that would be
INSERT INTO <table> (<column name 1>) VALUES (<value 1>);
where you can choose an arbitrary collection of columns, but must give one value per column (e.g.)
INSERT INTO <table> (<column name 1>, <col 2>) VALUES (<value 1>, <val 2>);
It looks like these operations should be available without requiring an executed manual statement though - see
DB Tools Insert Data (wire the columns array to specify columns)
DB Tools Update Data
GCentral
Message 3 of 10
(4,465 Views)
Could you please provide an example, because I tried using insert in to data db vi, using this I can write all the column values but not specific column. My end goal is - I have an1D array and I need to add all the array values in one of the column. Hope this is clear. Thanks
Message 4 of 10
(4,431 Views)
I would expect the following to be what you're looking for:
GCentral
Message 5 of 10
(4,422 Views)
Message 6 of 10
(4,409 Views)
Thank you!. Yes I tried it, but it  is updating always with last value ( refer screenshot)
Message 7 of 10
(4,402 Views)
I think you can simplify your Database read to 2Darray by replacing the double for loop with a 2D string array constant to the Variant to data.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 10
(4,398 Views)
Solved!! 🙂 Thanks everyone. I have added a condition!
Message 9 of 10
(4,394 Views)
Oops! Sorry, you mentioned inserting previously so I though you were going to have default values in the other columns.
For update (as you already found) you can use a condition (like WHERE blah=<value> in SQL) to only update specific rows, or else all are updated, repeatedly, leading to them finally all having same value as you saw! (earlier in the VI's execution, they'd all have the value 1, then 2, then 3, etc).
GCentral
Message 10 of 10
(4,392 Views)
