how to use same controls in different tabs
hi,
is there any way to use same control(switch) in different tabs in a vi, if i can't able to do it then how to update the value of switch between tabs
Message 1 of 13
(6,728 Views)
No.
You have a couple options.
1.  Have a single control that is not on any tab.  Have it be visible or not, and location placed (via. property nodes) depending on which tab is visible at the the time.
2.  Have multiple controls on the respective tabs.  Have an event structure that is fired by the Value change property on each of those controls.  When a control is updated, then have the event structure update the value of all the other "duplicate" controls.
Message 2 of 13
(6,716 Views)
i am using latch mechanical action so icant able usenvalue change property then how to solve this...
Message 3 of 13
(6,706 Views)
You could not make it latch action.  Let it be regular and have the event structure reset the control back to the False state once the event case executes.
That or use the other option I gave of a single control that is not on any tabs, but floats over the tab control with visibility and position controlled by the currently visible tab.  (Probably also driven by an event structure trigger off the tab control value change.
Message 4 of 13
(6,692 Views)
how to do that first case please share a example vi.
Message 5 of 13
(6,685 Views)
Message 6 of 13
(6,664 Views)
it is for using same controls in different pages of same tab, but i want same control to be used in different pages of different tab
Message 7 of 13
(6,645 Views)
If you are using latch mechanical, simply duplicate the same control in every tab you need, include every control the same event case...
Message 8 of 13
(6,625 Views)
Another solutuon could be to leave the control floating over the tab without put it in a particouar page. The only problem is that you see this control in all tab pages...
Message 9 of 13
(6,615 Views)
how to make control float in each ntab please share some example vi
Message 10 of 13
(6,606 Views)
