how to use activex
Hello all,
i'd like to use an activex component in Labview (exactly GPSTookKit, a
manager of NMEA protocol to retrieve Latitude and Longitude) ; it works well
in Visual Basic environment but when I use it in Labview the automatic
property settings requires me to input parameter as Variant, where Visual
Basic requires just a string
For istance, to open a connection on COM1 the sintax is:
object.Open (string)
where string is just "COM1"
In Labview the method Open requires a Variant(???) and not a string 😞
How to get the equivalent inputs in LAbview environment??
(2,600 Views)
Sometimes, you can just wire the string into that input and it will work.
Or use the To Variant element which in LabVIEW 8 is under Connectivity -> ActiveX
(2,595 Views)
