1335 errors while installing drivers
I'm getting  errors while installing the drivers. Both are 1335 on...dmxlvsupport.cab, and Cabs.w1.cab.
Most likely a corrupt or damaged disk. After chosing to ignore the errors and continue the install I recieved an error stating "The Labview run time engine 7.1.1 installation has failed w/ the following error, Internal error 2350."
I've tried reinstalling the drivers but I get a Installation Summary message saying "No software will be installed or removed" this leads me to believe all were installed succesfully.
I need to 1. Verify that the Labview install is ok, and 2. Verify that the drivers were installed succesfully.
I'm part of the IT Group and am performing this task for an end user, so my knowledge of the Labview functions are limited at best.
I've added attachments with screen shots of the errors.
OS: XP sp2
MSI: V 3.1
Labview V 8
Thanks in advance for any and all help.
(4,805 Views)
Hi 3DW,
I have seen cases where installation errors like the ones you mentioned in are fixed if you drag the installation files from the CD onto your desktop and install from that location (in case you need to install again).
I'm fairly certain your LabVIEW installation is okay (since that looked like a DAQ error) but you can check it just by opening up LabVIEW.  Checking your drivers is more difficult because the driverCD installs a number of different drivers.  I would guess that the DAQ drivers are the ones that you guys will be using so I'd focus on checking up on these.  Do you have any NI hardware in thie machine?  If so, you can check the DAQ drivers by going into Measurement & Automation Explorer (MAX).  Expand Devices & Interfaces and then DAQmx Devices and make sure that you hardware appears in this list.  You can right-click on the board and select "Self Test" to make sure everything is working properly.
I hope this is helpful.  If you are really concerned about all the drivers, you may want to just Repair the Installation.  Let us know if you have questions!
Good luck!
Megan B.
(4,791 Views)
Thanks for the reply, I was able to get it going. Installed the DAQ card and all seems well.
(4,786 Views)
