how to uninstall 2011
Maybe due to having 2011 beta, maybe not, but when installing the real 2011 it somehow forgot the labview.exe. Rerunning the installer says it's done, and in a slight rage i simply deleted the 2011 folder. It still thinks it's finished with the install and i have no 2011 ... Any ideas?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 1 of 9
(3,219 Views)
I'm guessing you tried Add and Remove Programs under the control panel and selecting repair?
LabVIEW 2012
Message 2 of 9
(3,207 Views)
Accepted by topic author Yamaeda
I think i've solved it, i couldnt find any uninstaller either, neither under LabVIEW nor National Instruments ... it's because it's sorted under 'S' for Software from National ... (doh, what's installed that isn't software?)
/Y
Qestit Systems
Message 3 of 9
(3,206 Views)
@Steve, as i didn't find the installer i went to the installer catalog and Products/install and repair from there ...
Qestit Systems
Message 4 of 9
(3,201 Views)
Oh boy...
I did something like that with 2010 and never got it "right" afterwards...
I guess there is no need to tell you to try uninstalling it from the Control Panel > Add Remove Programs > under National Instruments and then select LabVIEW 2011 to remove...
You'll probably need to clean the registry...
Wishing you luck..
Message 5 of 9
(3,200 Views)
Repeat that???
What S? Where?
Message 6 of 9
(3,198 Views)
"Repeat that???
What S? Where?"
For some reason it's not listed under National Instruments in add/remove programs, but "Programvara från National Instruments" (Software from National Instruments)
With that i could uninstall 2011 and then install normally. I sure hope it works as it should ... 🙂
/Y
Qestit Systems
Message 7 of 9
(3,189 Views)
You scared me for a moment..
In my case it's under National Instruments Software.
Message 8 of 9
(3,183 Views)
Yeah that makes more sense, it should have the name first "National Instrument-programvara"
/Y
Qestit Systems
Message 9 of 9
(3,171 Views)
