Passing file name during report generation using PDF 995
I am using Labview 2009. My application is to print pdf reports at the end of test. I am using PDF 995 to print reports send by Report generation Toolkit.
I am not able to define the file name based on test & other test parameters. I even tried to use PDF creator. There also i faced the same problem.
Is there a solution where i can print pdf reports with file name i want to.
Thanks in Advance
Abhimaniu
(2,516 Views)
Abhimaniu,
Try this one, its a free toolkit from Simplicity and made for LabVIEW.
http://www.simplicityai.co.uk/products_services/products/pdftoolkit/
Hope this helps.
aCe
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,500 Views)
