how to transfer a float number to boolean
I want to transfer a float number to a boolean array? How can I achieve?
Message 1 of 11
(3,570 Views)
Accepted by topic author YoungHang
Just refer to the example in this link: http://digital.ni.com/public.nsf/allkb/DD5AFE8E829DC16D86256BDF005E1F95
Hope that helps
Warmest regards,
Lennard.C
Learning new things everyday...
Message 2 of 11
(3,562 Views)
What will you do with the boolean array?
Certified LabVIEW Developer
Message 3 of 11
(3,560 Views)
output through NI PCI 6541
Message 4 of 11
(3,556 Views)
thank you so much!
Message 5 of 11
(3,550 Views)
another question: how can I thransfer a decimal to a 16bits binary number?
Message 6 of 11
(3,547 Views)
I would suggest that you should try it yourself before asking those questions. My suggestion is that you should play around with the example from the link I have sent to you and read the explaination in it as well.
Warmest regards,
Lennard.C
Message 7 of 11
(3,536 Views)
'Number to boolean array.'
Message 8 of 11
(3,530 Views)
but actually "number to boolean array" can only transfer a integer or fixed-point number to boolean array , not float number
Message 9 of 11
(3,510 Views)
Just typecast the DBL to U64 first.
Message 10 of 11
(3,502 Views)
