how to synchronize with single cycle timed loop
From within a SC Timed Loop I need to send some sort of synchronization signal back to the Host computer. I cannot set an interrupt because it takes two cycles to execute. I tried to get around this limitation by setting an occurance.  Another loop that is not a SCTL is waiting on the Occurance and sends the interrupt. This doesn't work either because signals cannot cross "timing domains". Has anybody figured a way around this?
Perhaps one could toggle an output bit in the SCTL, externally wire it to a different input pin, then have the 'regular' loop sense that and send the interrupt.
(4,243 Views)
Hi Paul,
Is this SCTL on the Real-Time Controller or on the FPGA? Outputting to a physical line may take much longer than a clock cycle depending on the clock used. Have you tried writing to a datasocket and reading it on the host computer and send your execution signal that way?
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(4,210 Views)
Andrew,
Sorry that I didn't mention it but the target is an FPGA on a PCI-8713. I am running the clock at 26 MHz.
The main purpose of the loop is to produce a complex sequence of interrelated and fully adjustable timing pulses for a radar system.
I can program in a number of repetitions of a given sequence. I am looking for a way to inform the host that it is doing the last repeat.
Paul
(4,194 Views)
Hi Paul,
I would suggest using a dma fifo to transfer a signal back to your host vi from the fpga.
(4,159 Views)
Andrew,
I have another FPGA application that uses FIFOs. It is a SPI bus master state machine using SCTL. FIFOs in both directions work well and reliably. The only problem is that I notice some jitter which I write off to the DMA and perhaps some Memory allocation that the Operating system gets involved with now and then. I had been thinking of using a FIFO here in this timing application as you suggest, but I was holding off to see if something better (more deterministic) might show up. I realize that with Windows even an interrupt is a shot in the dark. Because you fellow wizards have come to the same conclusion, i.e. there is no other or easy way to do it, I think I will go ahead and implement it. I believe that I can have the host wait for a message from the FIFO and with a timeout too, rather than poll for it.  Thanks
(4,148 Views)
