how to synchronize two counters
I am using two counters to run two loops with a delay between each loop. I find that the two counters that I use are not synchronized. How do I synchronize my counters? The DAQ board I have is MIO16-E1.
(2,637 Views)
I'm not familiar with that board, but does it have an external trigger for each counter? If so you could tie the external trigger inputs together and trigger them externally with a DIO or a line from the parallel port. Then they would be in sync.
- tbob
Inventor of the WORM Global
(2,632 Views)
