how to show duplicate scale programatically on chart indicator?
i am using chart indicator..... i bundled different range of channels and want to show the duplicate y scale by programatically...?
Balaji DP
(3,017 Views)
With the YScale.Visible property. Make to to select the acive scale first?
Did you look through the available properties before posting this question? Do you work with the context help window open?
(3,015 Views)
Note that you have to create the different Y scales before runnning or this will not work.  Do this in the development environment by right clicking on the scale and selecting Duplicate Scale.  This cannot be done at run time.
(2,982 Views)
