create shear stress formula
Hi everyone!
I want to create a formula to use it later in order to take integral and derivative of this equation. The equation has some constants of D=0.026 m; L=3 m. And some other constants which are found at the end of the run in vi. These constants are numerics which are "delta_P_ta"; "delta_P_os"; "U_m_os" and "w=2*pi*freq.". The formula I want to obtain is;
Shear_stress_wall(t)= (delta_P_ta*D/4/L) + (delta_P_os*cos(w*t)*D/4/L) + (1,2*w*D*U_m_os*sin(w*t)/4)
where t is time in second and the shear stress wall is a function of sin, cos and t. Then I will take derivative of this equation with respect to t.
Please help me!!! Is it possible to generate a string and is it possible to use this formula string in order to take its integral??
Is it also possible to draw this equation into waveform graph with respect to time?
Please help me! Thanks a lot!
Message 1 of 34
(5,984 Views)
Try Formula Node from structure palette with your formula?
CLD
Message 2 of 34
(5,967 Views)
LabVIEW does not do symbolic math. Your best bet is to program the integral function and derivative functions manually. Use something that can do symbolic math (such as maple) if you have difficulty with this.
That makes no sense. Your function depends on "t" only (since you apparently know "freq" and other constants.). "Sin" and "cos" are trigonometric functions, not independent variables, right?
If you just want to draw the function, integral, and derivative in a graph and don't require an analytic representation, just calculate your function for a sufficient number of regularly spaced "t" points, then use numeric integration and differentiation. LabVIEW has alll the tools for a numeric solution.
Message 3 of 34
(5,964 Views)
Hi altenbach,
Thanks for your reply.
I have a numeric constants as a result of the vi run, which are "freq."; "delta_P_ta"; "delta_P_os" and "U_m_os".
For example; delta_P_ta= 120 Pa;  delta_P_os=30 Pa  and U_m_os=0.8 m/s. How can I insert these values into the given formula below and then integrate it and draw as a waveform graph in the same vi in which "delta_P_ta"; "delta_P_os" and "U_m_os" are calculated?
The general view of the equation in which the calculated variables will be inserted is:
shear_stress_wall= (0,0266*delta_P_ta/12) + (0,0266*delta_P_os* cos (2*pi*freq.*t)/12) + (0,03192*2*pi*freq.*U_m_os* sin(2*pi*freq.*t)/4)
The four values will be inserted the given equation and the equation will be as a function of only t (time). Then I will integrate it with respect to t and also I will draw this equation with respect to time for example between t=0 and t=50 sec.
Please help me! Can I use "Formula Node" for this?  Thanks a lot again.
Message 4 of 34
(5,957 Views)
Hi Ivrat,
I have tried "Formula Node" but I failed. I am a beginner in LabView and can not use the "Formula Node" well.
Could you please help me to obtain the formula in the previously given format using i.e., delta_P_ta=120; delta_P_os=20; U_m_os= 0,5 and freq. =1.
Could you please construct the block diagram of this?
Please help more!
Message 5 of 34
(5,956 Views)
Hello Mechen,
Here's one way of implementing it using MathScript Node and For Loop.
I would probably use Control Design and Simulation Loop in place of the For Loop if you are looking to take integral & derivative of the function with variable step size solvers.
Hope this helps.
Andy Chang
Message 6 of 34
(5,945 Views)
Andy Chang
Message 7 of 34
(5,944 Views)
Mathscript and control&simulation are both optional toolkits. I would recommend to stick with a plain LabVIEW solution.
Message 8 of 34
(5,935 Views)
Hi altenbach,
What do you mean about plain LabView solution? Could you please give an example vi about this? Thanks again.
Message 9 of 34
(5,926 Views)
Hi Andy,
thanks a lot for your solution. I hope it will work when I construct it in my vi. If I have a trouble, I will want a help. Thanks again.
Message 10 of 34
(5,922 Views)
