how to share the value of two control ?
I'm a beginner with Labview, and I after reading the doc, I've not found
how to use two control to generate the same variable : I need a Dial AND
a numeric control (in order to be more accurate) for the same variable.
Is there a way to do it ?
Sincerely,
JH
(3,050 Views)
if you need to use  a dial simply select it, press right mouse button and from "visible items" choose "digital diplay".
You can change "format and precision" to get the desired "precision".
Bye
CLD - Labview Certified Developer
(3,046 Views)
antea06 a écrit :
> Hi,
> Bye
very good, I didn't seen this option. Thanks a lot.
JH
(3,039 Views)
Hi JH,
Since you mentioned you were a new user, I thought I'd chime in with some really helpful links.  First of all, there are some helpful introductions to LabVIEW on ni.com:
Three Hour Introduction to LabVIEW
Six Hour Introduction to LabVIEW
These courses will help give you a foundation on dataflow, which is essential to LabVIEW programming.  You can also search the KnowledgeBases (there are thousands) and the Example Code on Developer's Zone.
I hope this helps you get started!
Megan B.
(3,020 Views)
