how to setup the windows installed pxi to RT target
how to setup the windows installed pxi to RT target?
(3,238 Views)
Well, you wrote it twice, once in the subject, once in the message body.  It didn't make it any clearer as to what you are asking for.
Please provide a little more detail as to what you are trying to do and where you are stuck.
(3,230 Views)
sorry for t,hat... I was working on existing RT project which has RT code and fpga code. before i came to the project pxi box was configured with PharLap RT installed. Now i got new pxi box with same hardware but only windows OS in it. below are my questions..
1. can i run existing project on windows installed pxi?
2. What are all needs be there to say it is a RT taget?
3. can i run existing RT code on windows, download fpga code and make it work together in same box
Thanks in advance,
Ranjith
(3,223 Views)
Ranjith,
I think the answer for your 1st que is NO. In the sense, you can run the code, but it may not work precisely as it is supposed to...
A target can be said to be an RT, if & only if it has an RTOS installed in it, not just Windows, which is not a real-time OS.
Youcan run the existing code in Windows, but as I said earlier, it may not give you the actual results.
Finally, hereafter, pl dont use the term 'box' for a PXI. It is a chassis with a main module that runs on Windows or an embedded RT processor/conrtoller that runs on an RTOS like VxWorks or Phsr Lap.
Hope this helps you to some extent...
- Partha ( CLD until Oct 2027 🙂 )
(3,217 Views)
1. i would like to test my code on windows with fpga. how do i do this?
       - how to download fpga code
       - how to keep my binary on OS startup
       - how to configure windows installed PXI chassis to see on network/MAX
2. if i have to install RTOS, what is the procedure to do it?
I have several questions like above.. are there any guidelines which i can go thru and setup my PXI chassis as required.
(3,215 Views)
Hi, Ranjith
This might help you as your problems are very generic
1. To trouble shoot PXI,  http://zone.ni.com/devzone/cda/tut/p/id/5403
2. About usingPXI with FPGA, http://www.ni.com/flexrio/
-Mallya
" Appreciate and motivate those who help"
(3,200 Views)
I think some of the embedded PXI RT controllers come with preloaded RTOS.
I m not sure about the rest of your queries. May be you can contact the local NI in India.
(3,190 Views)
