how to set the default value during run time ?
Dear all,
i want to know how can i set the default value of a numeric control during run time ?
Ritesh
(4,679 Views)
Enter the number you like in the control. Then right click the control and choose "Make current value default".
Mathan
(4,675 Views)
You can't set default values during run-time. These values stored in executable, and you can't modify executable.
You can only reinitialize control to default value.
So, you need to store your "default" values somewhere outside of executable - in ini file, or in registry. OpenG tools also very helpful.
Andrey.
(4,665 Views)
