how can i send a image file on serial or audio file
  sir
  i want to tranfer an audio or image file through serial port so how can i do that?
(4,197 Views)
Hi maak,
please post in this thread. You got already answers there.
Mike
(4,195 Views)
hello sir.
                   I am Prabhu from chennai. i dowing new project in vision. it is "image transmission through serial port". but sum errors in this project. that is array(converted image) value is not convet in to image file.  i attach this file please check this. and reply me my mail id: kgp.usic@gmail.com
(4,153 Views)
Hi friends
I am Joseph from London. I am trying to find the answer of your question so can you send some detail of the above question.
Joseph
(4,145 Views)
hello sir
                thanks for your reply.
i doing new project in vision. it is "image transmission through serial port". but sum errors in this project.
that is first one image file(jpeg,bmp) is converted to array format .
and array value converted to spreadsheet string. this string value send through visa serial writh vi.
errors:
but visa serial receiver vi is not accept this  string value.;
& array(converted image) value is not convet in to image file.
pleas explain the IMAQ array to image (convertion) . vi
(4,125 Views)
Hi i want im...,
i can't open your vi, but it sounds for me like you can use the "Flatten to string" function.
Mike
(4,121 Views)
