how to select three replies and combine them to get a decimal number
i have got a translation stage . For stopping the transaltion stage i need to give the  attached program . Here the commands 165-167 will yield the number of steps moved . the replies of these commands will be a byte length>255. So these three numbers on joining will yield the required step count. So can I get help to take out these three values out of four loop and combine them selectively from the entire other command replies. I will give an example for that
165--50
166--195
167--00
this yields step count of 50000.
if you need clarification please kindly ask me
(2,512 Views)
Hi perumpadapu,
this has been explained to you several times before...
- Solution is given here or here!
- As explained before: your example doesn't give 50000, it only gives 49970!
Do you read any of our answers?
Why do you start new threads again and again? Stick with your original thread!
(2,505 Views)
sorry for the trouble. when I tried that with a selection from array. it have some problem. so can you help me with a fresh snippet of what you answer, so I can understand it. from all your answers i 'am in confusion . So can you kindly send me a snippet of waht your answer . please kindly send me if you have time.
(2,494 Views)
Why should I repost the snippets of your other thread - the same I have linked to in my previous post?
(2,474 Views)
