how to select case structure based on ranges, i have 4 ranges i.e 0 to 1000, 1001 to 5000,5001 to 15000,15001 to 30000. here my Question is how can i write a code to select one range from them rendomly
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,768 Views)
Hi srini,
here's another method:
Set the other cases as needed...
(3,761 Views)
Accepted by SrinivasB
Gerd's is the easiest way to go.  To clearify, you can create a range for a case in a Case Structure using "..".  So "0..1000" will execute that case for all numbers from 0 to 1000 inclusive.  But also note that the case structure doesn't exactly work with floating point numbers.  It works with integers.  When you wire a floating point to the case selector, it converts it to an integer.  That's just something to keep in mind.
(3,744 Views)
Is there any way, I can remove the coercion dot in my example (U8 to enum indicator)??
(3,737 Views)
Check out this idea:Officially Support "Coerce to Type"
(3,734 Views)
