how to save the current access database as a new file with a specified name
what I am trying to do is after writing data to a public access file, save it as a new access file,
clear the public access file and write new data in it.
repeat the above process when requested by the operator.
which database function should I use to execute this "save as " action?
thank you...
(4,272 Views)
I'm not sure what DB tools you are using in LabVIEW however I was able to locate the following function that seems to accomplish what you asked about.
DB Tools Save Recordset To File VI: http://zone.ni.com/reference/en-XX/help/370016C-01/lvdatabase/db_tools_save_recordset_to_file/
As far as database applications go there are several examples included in LabVIEW some of which include SQL functions as well.
Isaac S.
Isaac S.
Applications Engineer
(4,248 Views)
Thanks for your reply, I hope to save the file as .mdb file (access database file)
I simply could not find the module that could possibly do that.
(4,242 Views)
Accepted by lksusier
Why not just use the normal file operation functions ?
There you can copy your Access file, it just a file.
You can find the copy function in the palette : Programming -> File I/O -> Adv File Funcs -> Copy
(4,239 Views)
Why are you creating a new access database for each new iteration???
This defeats the purpose of a database which is used generally used to store multiple sets of data.
(4,234 Views)
I figured this out yesterday. I was just stuck with the Database operations and completely forget the most basic functions. 😞
(4,224 Views)
Thanks for your reply.
That was a request from a databse programmer, I was told the file created will make it convenient for him to import data to another database.
anyway, just want to get it done so I can move on to more critical tasks.
(4,221 Views)
