how to save dynamic data to a spreadsheet with only two columns
I was looking for similar information therefore the previous submissions were extremely useful. I am now trying to call a ready template of spreadsheet and trying to dump all the data  into 3 seperate columns the already programmed spreadsheet will automatically raphs and calculate some values and then I can rename and save it for archiving. Could you advice me how to call an already programmed spreadsheet then write/dump some readings.
Duran
Message 11 of 16
(1,496 Views)
Hello, Duran,
one way would be to delve deep into the dungeons of Dynamic Data Exchange aka DDE.
There you'd open a DDE-connection to Excel, request it to open the desired file and poke data into the now opened file at specified locations. After poking, close DDE-channel and continue in Excel as desired.
There is a small demo for MSAccess in the Example library that you could use as a starting point. If that proves to difficult, repost.
The dde functions are not in the regular function palette, but you can get them by selecting
/'your LV path'/vi.lib/platform/dde.llb
Good luck
Michael
Message 12 of 16
(1,486 Views)
Thanks Michael,
I think the way you are suggesting is a potential solution to my problem but I am quite new to Labview programming and not sure how to start. I have attached the VI I am working on could you help me to progress with this problem
Thanks again
Duran
Message 13 of 16
(1,483 Views)
Sorry - can you save it in a 8.0 vi? I have not updated yet... thnx
Message 14 of 16
(1,480 Views)
I hope this will be better.Thanks very much
Message 15 of 16
(1,474 Views)
Sorry - there was some loading error due to an ExpressVI not supported in 8.0. I'll look for an updated machine here and see what I can do...
Message 16 of 16
(1,460 Views)
